Problem with build
The Front panel disappers when application is run. But without build it is working fine. Labview 11 and service pack 1. Please!
(2,601 Views)
As I understand from your statement:go to
FILE>>VI properties>>window Appearence>>customise
Then you should enable "show front panel when called".
If it is not your problem please give a detailed explanation of your problem.
Thanks as kudos only:)
(2,598 Views)
You should be having an error while running exe (may be a path error) thats why it starts and encounetrs error and stops so the front panel disappears and with no error your vi is running and the front panel is open. Give a more detailed description to understand the probelm better.
(2,586 Views)
