Problem with cluster array
Hello.
I'm using the "Bundle" function to group several variables of different types into a cluster. This cluster needs to be grouped with other similar clusters into a cluster array to be used in the "Flatten to XML" function.
My problem occurs when I try to create the array of clusters using clusters of different sizes (one with 9 elements and another with 12 elements). I'm using the "Build Cluster Array" function for that, and it gives me a wiring type error, as the attached snapshot shows.
Does anybody have any suggestions on how to solve this problem?
Thanks!
(3,479 Views)
You can't bundle different clusters into a cluster array. They must be identical.Smiley Happy
PaulG.
Retired
(3,465 Views)
All elements in an array must be of identical type, only the values can vary.
Maybe you can bundle your clusters instead?
(3,457 Views)
So, how can I do it then?
I just want to send everything to a XML file (using Flatten to XML). This function accepts anything as an input. So, I believe it's just a matter of concatenating all the clusters' bundles, right? But how can I do that? I can't find a "concatenate clusters" funcition...
Thanks a lot for the help!
Daniel
(3,428 Views)
It's called the bundle function. You can wire in separate clusters and output a cluster of clusters.
(3,425 Views)
Dugh.....!
I'm so stupid... I was already using that function to the other part....Smiley Surprised
It works fine now. Thank you all for the great help.
Daniel
(3,410 Views)
