Problem with consumer/producer loop.
Message 11 of 25
(1,865 Views)
I changed the error shift register as suggested to a tunnel and it didn't seem to make a difference.
Message 12 of 25
(1,861 Views)
OK, did you look at the contents of the error line?
Are you having an error, or not?
Create an indicator, or put a probe on the wire, to answer that.
Steve Bird
Culverson.com
LinkedIn
Message 13 of 25
(1,858 Views)
I'm not getting an error. (See 6.vi)
Message 14 of 25
(1,849 Views)
OK, so follow the steps I described - is the NEXT STATE thing showing what you expect?
Steve Bird
Culverson.com
LinkedIn
Message 15 of 25
(1,846 Views)
It is not showing what I expect. It is showing "Start BurnIn" and I expect it to be showing TimeCheck.
Message 16 of 25
(1,840 Views)
OK, keep chasing it backwards.  If it's not coming out, is it in fact going IN TO the queue?
Consider what you're doing - you are DE_QEUEUEing an element, and then you immediately FLUSH THE QUEUE.
Why is that?  That means your queue can never hold more than one element, which sort of defeats the purpose of the queue.
Steve Bird
Culverson.com
LinkedIn
Message 17 of 25
(1,835 Views)
Send a snap-shot if the VI heirachy with type-defs.  I'm thinking if the value in the cluster isnt what you expect-its being coerced from a divergent teyp-def
Message 18 of 25
(1,833 Views)
I've attached the VI Hierarchy.
Message 19 of 25
(1,822 Views)
That's possible, Jeff, but flushing the queue is a great big pothole into which could fall the missing cluster.
Steve Bird
Culverson.com
LinkedIn
Message 20 of 25
(1,821 Views)
