Problem with counter
Hello.
I am trying to write a VI that implements a counter. I have pulses of signals coming from a sensor and i need to measure the number of pulses received per second. Basically i need to design a VI to find RPM from my sensor.
I want to count the number of pulses received in one second from the sensor, use that to find rpm and then reset the counter after that everytime so that i can use it again and display rpm at every second.
Thanks in advance 🙂
(3,239 Views)
Hi Solanki,
What kind of hardware do you have ? How do you plan to acquire the output signal of your sensor ?
CLAMaxime -- Kudos are a great way to say thank you
(3,208 Views)
I have a myRIO 1900 and I will be getting the pulses from an ECU.. It has been customized that way..
But for now, I'm simulating this code using signal generators.. No hardware connected..
I have attached my VI for reference..  Also, If i could get help with higher frequencies, that would be great..
P.S I'm a beginner at LabVIEW so.. :3
(3,162 Views)
