Problem with creating an Infrastructure Network (via Access Point) for WLS 9163.
I am trying to connect the WLS 9163 to an Infrastructure Network (via an Access Point). I have connected it via an Ethernet cable and am using MAX to configure it.
The setting are as below:
Obtain IP Address through: DHCP
Country: US
Radio On: Yes
SSID: wireless (selected from drop down implying the wireless network is detected)
Wireless Mode: Infrastructure
Authentication: Open
After doing these settings, I click on Save Settings. The device reboots itself and takes the IP address, Subnet mask and default Gateway automatically. The WLS link LED on the device is also turned on. The System State is 'Connected' and both the Wired and Wireless Connection Status is shown as 'UP'.
So far so good.
Now if I remove the wired connection and refresh the device, it does not get connected via wireless (which I believe it ideally should). The System State is shown as Disconnected.
I am using a Phoenix Contact WAP and have set the authentication as Open.
Please suggest some solution.
(3,280 Views)
I had this exact same problem and it took me a while to figure out. As strange as this sounds, I figured out that for some reason if I had the WLS-9163 too close to the router and I pulled the wired connection, the wireless connection could drop. I read on a post in a different forum about someone removing their antenna and it working just fine so I tried that and it worked off and on but mostly off. So I figured out that the further distance away I was the better the connection stability was and I got far enough away from the router to where it was a steady solid wireless connection. This sounds really backwards from what it should be and was really bizarre but I tried different routers, used all different types of settings, had the latest firmware and had all of the equipment sitting on my desk and could not get it working once I removed the wired connection. This may not solve your problem but this worked for me so I thought I'd share that info. I was just so shocked to figure out being too close to the router seemed to be screwing my stuff up.
(3,091 Views)
