Problem with database connectivity in run time system
It is there in my windows 7. Use udl file if you are not. Here is the file.(Needs to be extract as I cant upload ud file directly)..
One more thing. This question is solved. If you want to ask something then create new question and tage the person you think will help.
Make this habbit.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 26
(2,024 Views)
Dear Mike,
My application has database connectivity (developement system is windows xp).  I have used "microsoft OLE DB jet 4.0" provider; it is working well on windows xp (developement system as well as stand alone system).  But when I install it on a windows 7 pc every thing works except the database write.  After your reply I have tried on three diffrent windows 7 machine, but couldnt suceed.
I have attached a photograph; please have a look and suggest.
Message 12 of 26
(2,023 Views)
I suggest you read the error message. It tells you right there that it can't find the database file that you are trying to connect to.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 26
(2,017 Views)
Sorry, double post...
Mike...
LabVIEW Champion
Message 14 of 26
(2,012 Views)
It says your DB file not found. Put one indicator and see. Have you stored the VI? Store it and then run and see what path it is taking.
--Ranjeet
Message 15 of 26
(2,001 Views)
As you see appended path and path in error message is different. Answer lies in error out
--Ranjeet
Message 16 of 26
(2,000 Views)
Dear Ranjit,
The apended path as well as the path in error msg are same.  And I have checked my database file is also located at the same place.
I think it is an issue related to 32-bit and 64-bit.  My developement system is a 32-bit machine where as the run time system is a 64-bit machine
Message 17 of 26
(1,990 Views)
Sorry I didnt see that.. there is ofcourse no problem with bits
--Ranjeet
Message 18 of 26
(1,981 Views)
See this . This might help
also this
--Ranjeet
Message 19 of 26
(1,980 Views)
I need your VI.
--Ranjeet
Message 20 of 26
(1,977 Views)
