Problem with displaying image after image processing
I need to do an image process(to get some info) but after I do it original i can't print the original image.
(5,962 Views)
If you want to preserve original image without being changed, You should copy(IMAQ Copy) the original image to another buffer by creating user buffer( IMAQ create).
uday
(5,955 Views)
I still have the same problem
(5,945 Views)
Accepted by topic author aaa_aaa
The default Image Type is grayscale. You need to create RGB(U32) type buffer.
Spoiler
For Your problem: Just use IMAQ Create and give a meaning full name and not untitled, with default ImageType and connect to Image Dst input of IMAQ ExtractSingleColorPlane.
-The code is not at all following DATA FLOW principle on which LabVIEW works.
-Please refrain from using Express VIs and start using Low-level VIs.
-Please go through below links to start learning about LabVIEW
NI Learning Center
NI Getting Started
LabVEW Basics
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
LabVIEW Graphical Programming Course
Using the Context Help Window
LabVIEW Inbuilt Examples
uday
(5,935 Views)
You aren't making the copy until after the loop is finished and the image is already modified
(5,930 Views)
thank you I solved my changing name I know I have to go through some tutorials I don't have time right now. I will keep using the Image acqusition But I won't use vision asistan as an express.
Why the "untitled" didn't work
(5,911 Views)
(2,682 Views)
