Problem with distribution dependency when I try and build an installer
I'm having a problem building an installer for my Labview program. What is happening is this:
The EXE builds OK but when I try and build the installer I get a window asking me to find a distribution called 'Beverage-Air lab assistant' (this is the name of my application). When I click the plus sign next to this distribution in the popup I see all NI packages including
DAQmx8.8
Measurement and Automation Explorer 4.5
Labview Runtime
etc, etc, etc
In any case it seems like Labview has gotten confused somehow and thinks that these things should come from my files as opposed to the files installed with Labview.
I'm going to try installing Labview on another PC and try building my application to see if maybe the installation of labview is to blame but beyond that I have no idea where to go from here. If anyone has any ideas please let me know.
Scott Crook
Automation Engineer
Beverage-Air Corporation
(2,490 Views)
I've gotten this confusion happen to me before, and the only solution I could come up with was a full uninstall and reinstall of LabVIEW :(.  It happens whenever I do an "upgrade" install instead of a clean install of LabVIEW.
(2,484 Views)
