Problem with driver of Chroma DC power supply
I need to replace the power supply in the program with Chroma 62006P-30-80. The drivers from NI and Chroma return error code -1073807339/BFFF0015. "Reset Configuration Data" doesn’t help. Can you please help. Thanks
(2,646 Views)
Hello, I see that you are using LabVIEW: this board is dedicate to another IDE, I notified the moderators to move your message to the appropriate board.
(2,636 Views)
