Problem with focus
I've a problem with the focus: I think the solution should be quite easy, but I've been looking for it for half an hour without results
I want to give the focus to a string indicator, because I want to see the blinking vertical cursor. (I know I could obtain the same result clicking on the indicator, but my program must run on a PC without mouse)
I made a simple test program (attached), that sometimes works, but almost often it doesn't.
I used the led in the while loop, and I see that tha string indicator hasn't the focus, even if I give it before. (this program must run on linux, so I tried in on a Fedora Core 3)
Where is the problem?
Using LV 6.1 on Linux Fedora Core 3
Message Edited by vix on 09-27-2005 11:40 AM
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,259 Views)
Hi vix,
To make key focus to a string CONTROL is easy and you already did it in the example. What you are asking for is key focus on string INDICATOR. and Indicator means that its not a user input. So change it to control if its meant to be a control (user input) and try running the application again.
good luck
Tareq
(3,248 Views)
Hi vix
After doing what Tareg stated, If you want to make sure key focus stays in that string control, put the property node inside the while loop.
If it is out,  and sombody press TAB key or does something in another control/indicator, you will loose it.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,237 Views)
Ok, you're right fot the difference CONTROL / INDICATOR;
but the problem is that my example (with the CONTROL) only works on Windows, but doesn't on Linux (Fedora Core 3), and I want to use it on Linux
Vix
Using LV from 7
(3,229 Views)
I tested the VI with LV 7.1 on Linux Mandrake 10.1 and it works exatly
the same way as it does on Windows. Here is a link to the FAQ "NI and Linux":
http://www.ni.com/linux/support.htm#2
You will find some interesting information, in particular with regard to
the currently supported Linux distributions. The error may be an issue
related to the Fedora distribution.
Bye,
Matteo F.
AE - NI italy
(3,210 Views)
