Problem with frequency
I have a problem, I need to determine several frequencies on one signal (the green signal on the picture...). How can I do that ? I tried with extract single tone information but it's not so good...
Thank you
(2,665 Views)
Extract Single Tone Information.vi should work, what exactly is the problem? Can you post the data (your VI with graph data saved as default) and explain what result you expect to find (and do not detect with the tool)?
(2,665 Views)
