Problem with graph palette and application
I'm using LV 8.5 and do have the following problem:
The graph palette of a xy graph is only visible within the LV development environment.
When I build the executable version of my application the graph palette is not visible - but I did not
implement code to hide programmaticly the graph palette.
What could be the reason?
Christian
(3,231 Views)
This is either a bug in LabVIEW, or a bug in your code.
Can you post a reduced example demonstrating the problem (only the VI, not
the exe)?
Wiebe.
(3,219 Views)
here the sample code.
It was previosly written in LV6 I believe.
Christian
(3,216 Views)
I´ve taken the XY Graph.vi from examples and changed it a little bit (it´s only an example). I´ve build an application from it and in both, .vi and .exe the graph palette is visible.
Try to exchange the graph in your VI with a new one.
Rebecca Fox
(3,203 Views)
