Problem with malleable VI
Hello everybody,
I'm starting with the malleable VIs and I have some problems in one of them (I attach it). I can't find out why I have broken wires when I connect arrays in the inputs and the output.
I want a VI that allows me to connect DBLs in the inputs and receive DBL in the output, and also to connect arrays of DBL in the inputs and receive array of DBL in the output, but I don't know what I'm doing wrong.
Also, if you see some other errors you could share them with me in order to learn better and faster.
Thank you so much for your time,
EMCCi
(3,253 Views)
18 is pretty new, you might get better response if you save to 17, or an image.
(3,216 Views)
Accepted by topic author EMCCi
It works for me.  Note that if you're wiring in arrays, you must wire all 4 inputs before the wires aren't broken.
(3,195 Views)
It's working now, after restarting labview. I don't know if it was a labview bug or that I missed connecting a non-array control to the VI.
Thank you anyway. Next time I will upload it in a previous version too.
EMCCi
(3,161 Views)
