Problem with mixed graph
Hello.
I'm trying to plot data into a mixed graph (Analog and digital). The purpose od the code is to plot tha data comming from a TDMS file. I have generated two tree viewers with the data from the TDMS. The user selectes in each one the data to be drawn. I generate the analog and digital data according to the selection and later I mix all of them into the graph. It works fine, but I'm having problems changing the plot names and sometimes the x Scale starts moving. I have attached the code and I hope you can help me. I have spent a lot of time without any success result.
Thanls in advance!!!
Miguel.
Message 1 of 1
(2,944 Views)
