Problem with parameterized procedure in Labview and Oracle9i
Hi Simbani,
I think this error has been generated by the Microsoft OLE DB Provider for ODBC. Since it seems to be a 3rd party problem, I don't have a lot of information on potential fixes, but I did find a suggestion that you manually create the SQL Query using the INSERT INTO command.
You can found on this link : http://zone.ni.com/devzone/devzone.nsf/webcategories/0F9EE47C28AA0628862567AC004EDCE3, example to create directly SQL command.
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
Message 11 of 19
(2,196 Views)
Hello National France,
Thanks.
I am using the Oracle OLE DB Provider for ODBC not the Microsoft one
Simbani
Message 12 of 19
(2,186 Views)
In some versions of Oracle, or with certain ODBC providers, the Microsoft ADO client cannot retrieve the properties requested by the Connection Get Properties VI.
Fortunately, most other commands and requests will execute without problem, and the only property that DB Tools Create Parameterized Query uses is the command timeout limit (as is explained in the block diagram). You can very easily modify the block diagram to specify its own timeout that is appropriate for your application. Save the VI with a new name and you will be able to use it in place of the original VI.
Check, that you have the latest version of Microsoft ADO, and Oracle's ODBC provider, .
http://zone.ni.com/devzone/conceptd.nsf/webmain/fa0a99e9bd96c8e98625713d007167ec
http://forums.ni.com/ni/board/message?board.id=170&message.id=71939&requireLogin=False
Christophe S.
Message 13 of 19
(2,173 Views)
Hello Christoph,
I am attaching the DB Tools Create parameterized Query Simbani.vi in which I have a timeout constant of 20. ¿This is what you mean? ¿How do I know the rigth timeout for my application?.
I suppose that if I delate the timeout input from the Property Node Command the *.vi will work well, but it will wait for ever should anything goes wrong. Then, I could wire a rather high timeout value such as 20. Am I right ?
Thanks ad regards
Simbani
Message 14 of 19
(2,166 Views)
HI,
   Have you already found the solution? I am also facing same problem, but I am using LabView 8.0 and Orcle 10.2 version. Thank you in advanced for your reply.
With Regards,
Tin
Message 15 of 19
(1,760 Views)
Hi Tin
Unfortunately, I did not find any solution.
Regards
Simbani
Message 16 of 19
(1,743 Views)
Hi Tin,
Are you also using the Oracle OLE DB Provider for ODBC?
Karunya Ravindran
Warm regards,
Karunya R
Message 17 of 19
(1,731 Views)
Karunya,
I am using Oracle ODBC
Simbani
Message 18 of 19
(1,719 Views)
Hi Simbani,
Like Christopher said, in certain ODBC providers, Microsoft ADO client cannot retrieve the properties requested by the Connection Get Properties VI.
Were you able to run the VI posted by on this discussion forum.
Your other option would be to purchase the NI Database Connectivity Toolkit.
Warm regards,
Karunya R
Message 19 of 19
(1,698 Views)
