Problem with program
Hello everyone,
I'm using the book graphical programming with labview and I am having a problem. I (think) I did the same as in the book. However, mine keeps saying that I am trying to connect two arrays with different dimensions. When I change the empty array constant attached to the for loop the program will run but it will not be the result it should be.
I included the labview vi. I'm hoping someone can help me out.
Bart
(3,634 Views)
Hi bart,
your VI hasn't any error. And there is no "empty array constant".
So what was your problem?
(3,630 Views)
Excuse me, I see I've send the wrong vi.
I've been stuck on this for a while now but I finally fixed it, I did not check concatenate inputs at built array. So I solved it, thanks for the help anyway.
(3,621 Views)
