Problem with running LabVIEW FPGA in Simulation, Error 2147467259
I've come across a problem when running LabVIEW FPGA code in simulation. I get a message as the following:-
LabVIEW FPGA called another software component, and that component returned the following error:
Error Code: -2147467259
Internal Error
LabVIEW 2019 terminates the program and I cannot run the program. I'm not sure if it's the same story when deployed.. Has any one come across the same problem? Any known fixes?
Message 1 of 1
(1,978 Views)
