Problem with serial port readings from LabVIEW to Arduino
First remove the from dynamic data type function. It does nothing for you. The chart does what you want by keeping a history but the array indicator won't you need a way to keep a history with a shift register. Just delete the array indicator to be able to run.
Right click the terminal leaving the for loop and choose last value which turns off auto indexing. This returns a scalar instead of an array.
Message 11 of 12
(686 Views)
All,
I'm really not sure how my thread from 2011 got resurrected but seeing as how I will again be interfacing Arduino with LabVIEW in the near future, I couldn't be happier!
Best of luck,
Yusif
Message 12 of 12
(667 Views)
