Problem with some values in text ring
I have a problem with the "text ring" control.
In my software, I need to update the text ring values, using a property node. But some values are not understood by the text ring, even if they are defined inside it.
I join you an illustration of my problem and the piece of code which doesn't work, I hope you can help me 🙂
Thank you,
Julie
(3,936 Views)
Accepted by topic author Juli4
Probably a result of the fact that floating point numbers can't exactly represent every real number.  So 0.4 is not exactly equal to 4e-7 x 1e6.
(3,932 Views)
Thank you for your help
(3,920 Views)
