Problem with special characters in a column
Hello, I call a data from a database and I do not have the rights on the database, the name of the columns have points in there name: Parameters.12V_Prog_IccType_A
Is there a way to solve this problem with out changing the name? Like using (), [], "", or something like that?
BR,
Robin
Message 1 of 9
(6,317 Views)
I didn't get properly what you are trying to do!
-what are points?
-If you want to search and replace in string use this: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/search-and-replace-string.html
uday
Message 2 of 9
(6,314 Views)
Hello thanks for your fast answer,
I mean points like this "." Parameters.12V_Prog_IccType_A.
Calling a column from a database with the DB Select Tool Kit, when I use this column it send me an error, but with all others the columns with out "." or "_" in characters it works, I am sure my problem is that point, but I can not change the name of the column in the table.
I can not replace the char in string or the name of the column will be incorrect.
Message 3 of 9
(6,309 Views)
Did you try putting the appropriate column string identifier around the column name? For MS-SQL I think it's a `, for MySQL I think you can use either " or '.
(blog)
Message 4 of 9
(6,300 Views)
The database using SQL server, I tried with " ", [ ] and ' '.
With ' ' it do not send me the value and send me the name of the column that I write in LabVIEW.
For example: 'Parameters.12V_Prog_IccType_A' -> Parameters.12V_Prog_IccType_A
And if the column does not exist it send me the name I entered anyway.
Do you know what can I use for SQL Server?
Message 5 of 9
(6,296 Views)
A ` is different to a ' (a subtle difference, but a difference all the same).
(blog)
Message 6 of 9
(6,288 Views)
Yes, I tried it and it did not work it say me the name is incorrect near '`'
But it was a good try, maybe something else? I sent a mail to them for changing the name of the columns, but it could be great to know what specific character I can use to make special character ok.
I had the same problem with the name of the table: Tests.Step1 but I just used " " and it works maybe LabVIEW can not do the same with columns?
Message 7 of 9
(6,284 Views)
Accepted by topic author Robinm76
Try the square brackets.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 9
(6,281 Views)
Everytime the good answer Mike! Thanks I understand now why it did not works the first time I used square brackets, I was using a string to pick the data in, and that was a float, but with the other error I never saw that problem. Great thanks for your help guys.
Robin
Message 9 of 9
(6,271 Views)
