Problem with stand alone application
Hi. This is my first time here in NI. Need support from the masters. This is the situation.
Main problem: Image display
When i try to make a standalone application, The "image display" vi wont work. Am i missing dll's here? Nothing seems wrong with the ni vision vi's. I can make ROI in the external window, etc.
I also tried to make a simple program that displays a white image using array to image but there is still no display.
Can i also ask what dll's are required to make a stand alone labview program with vision and imaq.
Message 1 of 9
(5,208 Views)
Hi Brein,
I think you have to include the NI vision tool kit while you are creating the installer (stand alone application) so that the required functions / dlls will automatically be connected with your stand alone application. This is possible only when your vision toolkit is licensed.
MRK (CLAD)
Message 2 of 9
(5,203 Views)
thanks for your reply.  What should i include in the stand alone application besides the labview runtime library and vision runtime library? Where will i find the toolkit? is it in the cd or in the computer with the installed softfare. Can you also post the directory of the toolkit so i can easily find it? thanks again
Message 3 of 9
(5,196 Views)
You will find the vision toolkit option in the additional insallers tab of the installer builder.
Message 4 of 9
(5,187 Views)
i can't find that feature in my labview. My labview version is 7.0
Message 5 of 9
(5,184 Views)
up this problem. Anyone who can solve this?
Message 6 of 9
(5,115 Views)
Message 7 of 9
(5,115 Views)
Accepted by topic author Brein
In order to deploy an application that uses the Vision Development Module functions, you would need the Vision Run-time engine and a run-time license for it on the deployment machine. If you are using the NI-IMAQdx driver for use with firewire or GigE cameras, you would also need a license for the Vision Acquisition Software on the deployment PC.
If you are not using the Vision Development Module functions or the NI-IMAQdx driver, all you would need is the NI-IMAQ driver. The Image display control started with NI-IMAQ 2.6, so make sure you install a version of NI-IMAQ that supports the Image display control and LabVIEW 7.0 on the deployment PC. Please refer to this webpage to check for NI-IMAQ and LabVIEW version compatibility: http://digital.ni.com/public.nsf/allkb/6B55FF09D1FBD3108625719600650B7C?OpenDocument .
Vivek Nath
Machine Vision
Message 8 of 9
(5,069 Views)
Thank you master, my problem is now solved and the display is now working fine. Now I have more reasons why i should use LABVIEW; Great technical support. Cheers to NI
Message 9 of 9
(5,011 Views)
