Problem with the control signal
 1. Why can not sign in time axis does not move at 256.
 2. I want the two signals. Defined as a signal X and Y, signal X = 10Hz (256 cycle / 25.6s) and
     signals Y =   1cycle / 25.6s. Then calculated and  writed program,
     but the program can not be controlled as desired.
Thank you
(3,206 Views)
I'm sorry, but I don't understand your question at all. Can you rephrase the question, or provide more detail? Perhaps posting in your native language may help.
(3,198 Views)
It would probably help if you used an XY Graph.
(3,197 Views)
From figure shown the signal on demand, signal X=256 cycle and signal Y=half cycle.
I think you get my program
Thank you
(3,166 Views)
Use a Waveform Data type and make sure the property "ignore attributes" is NOT checked.
When you do so, the dat is plotted as determined by "t0" and "dt" if you have more than one sample in the "Y" array.
The example I illustrated here deonstrates this feature.
Here is a preview that shows a chart with dat from multiple source coming in at different rates.
Ben
(3,156 Views)
