Problem with the "Read Delimited Spreadsheet VI"
I try to read a csv file with LabVIEW.
This is my VI for reading the csv file:
This is the ";" delimited csv-file, which I want to read:
This is what I get:
As you can see, there is a "0" in the first column and first row.
Does anybody know what causes this behaviour?
Thank you very much in advance.
Michael
Message 1 of 11
(3,526 Views)
Hello Michael,
I assume there is an (or several) additional character(s) at the start of your file.
For further analysis either upload the file or look at it in binary form.
Regards, Jens
Kudos are welcome...
Message 2 of 11
(3,517 Views)
Hello Jens,
thank you very much for your quick reply.
I attached the the file to this reply.
Michael
Message 3 of 11
(3,513 Views)
Accepted by topic author Michael_1122
Hi Michael,
as Jens told you: there are some additional bytes at the beginning of your file!
You probably edited that file using a text editor (like Notepad) instead of creating it directly from Excel…
See this view of your textfile using a hex viewer:
The first 3 bytes are used to determine the UTF status of that text file. LabVIEW doesn't handle those bytes explicitely and when reading a delimited text file it tries to convert that file content like any other file content…
Message 4 of 11
(3,496 Views)
Your file contains a three-byte Byte Order Mark (BOM) declaring that the file is encoded in UTF-8. In this case, it's a useless information since all characters are ASCII. LabVIEW does not support BOMs anyway.
You may set your editor options to avoid writing the BOM. As an alternative, open your file with Notepad, then choose Save As... setting ASCII as encoding options. See below (doing a little translation to your language):
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 5 of 11
(3,488 Views)
I meant ANSI, not ASCII...
Paolo
Message 6 of 11
(3,481 Views)
I think Notepad will make some guesses according to your localization.  I think that it will add BOM if you have non-English localization?  Something along those lines?
Bill
CLD
(Mid-Level minion.)
Message 7 of 11
(3,461 Views)
Not always. If I create form scratch a file with non-ASCII-standard characters, Notepad generates a UTF-8 file (i mean with multi-bytes characters), but does not prepend a BOM.
Honestly, all this character representation stuff is often a mess to me.
Paolo
Message 8 of 11
(3,450 Views)
Yes, I'm not sure exactly how it works, either, which is why I avoid working with Notepad.exe if at all possible.
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(3,436 Views)
Hello GerdW,
you were right. Thank you very much for your reply.
Michael
Message 10 of 11
(3,403 Views)
