Problem with time date convertion
Hello!! I saved a txt file with acquired data (with the funcion "write string to spreadsheet file") in this format:
hour.minutes.seconds     data0
nour.minutes.seconds     data1
Then I have to open this file and transform the first column in total seconds (each element of first column is in string format, the problem is that I have some dot to separe hour minutes and seconds):
tot seconds  data0
tot seconds  data1
I don't know how to do this.
I attach the file with saved data.
(3,253 Views)
Hi maumontesi,
wow, a German-style text file Smiley Wink
Read in the text file and convert the string(s) using 'Scan from string' with this format string: %d.%d.%d %,;%f (convert 3 integer numbers separated by points and one float with comma as decimal separator). Do simple math with those integers [total = (hours*60+minutes)*60+seconds].
Message Edited by GerdW on 05-04-2007 04:28 PM
(3,252 Views)
Thank you kindly!!!
(3,246 Views)
