Problem with wait function and simultaneous loops
I use a vi that simulates a choice between two circles or sides. Clicks on circles give points only after a certain delay fixed by an array constant.
I use two while loops (for programming events in each side) inside a while loop that fix the number of trials. It would stop after a fixed number of points gained. It was my first problem, I don't know how to do this.
The second problem is I would like to register the number of clicks on each side or circles during the wait function runs, so I would like to register all clicks on each side during the execution of the vi. I have found a way to count the number of clicks but not while the wait function runs because it blocks the execution of the vi.
Can you help me please. Thanks.
(3,140 Views)
Hi nousome,
I've made up a possible solution (attached) for what you're trying to do.  It's not exactly stellar code, but it shows a few things.
Instead of blocking execution with a wait, it checks the time of each button click.  If enough time hasn't elapsed since the last button click, the button click count isn't increased.
There are a lot of things that you could do differently for this: separate timers on for each button, separate exit conditions for each count, etc.
You might want to look up how the event loop/structure in my example works.  It's a little easier than checking mouse coordinates (and somewhat less susceptible to timing problems of control updates and property nodes).
Good luck,
Joe Z.
(3,122 Views)
Thank you very much for your solution. I have just modified some things to count the total number of clicks at left and at right.
(3,088 Views)
