Problem with waveform scale
Hello community 😉
I'm facing with graph analysis and I have graph measurement that sort out a table value with results formatted in this way: Table 1D, 1 to 4096 point and Y values corresponding.
The problem is that I want to change the data point sample value to the time corresponding to each samples. So I have 4096 points taken in a varaiable sample interval (15.6us up to 1second).
I've changed the Delta t scale with the sub panel vi available on the Waveform group but the problem is that each time I restart the vi the scale is changed and not fit my desired results
Thanks for any help....
I work in WinXP, LabVIEW 8.5
(2,986 Views)
All you need is a Build Waveform function to add the dt.
Message Edited by Dennis Knutson on 11-05-2007 10:51 AM
(2,981 Views)
Thanks for your reply, my problem is solved, have a nice day Smiley Happy
(2,958 Views)
