Problemm with the Goop Wizard while upgrading to LabVIEW 7.
I upgraded my LabVIEW from vers 6i to vers 7 and I've problemms with the Goop wizard, it doesn't appear in the Tools menu as it used. I supposse that I should upgrade the vers of my goop wizard too, but does anybody know if there is a goop wizard for LabVIEW7 and where could I doenload it from?
(2,958 Views)
I was able to install GOOP Wizard for 6.1 and use it without a problem in LabView 7.0.
(2,958 Views)
I was able too at the end, I had some messagge error at the beginning but when recompiled the programm I had no problemm. Thanks.
(2,958 Views)
If you use GOOP Wizard 1 (downloaded from NI), you have to reinstall it. Make sure you that the last LabVIEW version you start was LV7 (if you have multiple versions of LV installed). I don't know if GOOP Wizard 1 is supported in LabVIEW7 (Endevo does not support this tool anymore), it was developed in LV 5 I think.
GOOP Wizard 2.0 or 2.0.2
Make sure GOOPWiz2.llb is copied into the \project folder. Works on LabVIEW 6.0.2, 6.1 and 7.
GOOP Wizard 2.1
Run the setup.vi from the installation files of the toolkit. Works on LabVIEW 6.0.2, 6.1 and 7.
GOOP Inheritance Toolkit
Run the setup.vi from the installation files of the toolkit. works on LabVIEW 6.1 and LabVIEW 7
Mattias Ericsson
Main developer of the GOOP Wiza
rd 2 and GOOP Inheritance Toolkit.
(2,957 Views)
