Problems Communicating with non-NI hardware which previously worked!
I am currently carrying out a project with which I am using LabVIEW 7.1 involving communication with a non-NI board. This has proved succesful until I moved the system to another desk, (which had already been done a couple of times with no problems) and now I have moved it to its origional location. The system components have not changed, and the VI has not changed but now when I run the programme the error 'Error -1073807346 occurred at VISA Open in without graph2(backup4)..vi'   with the possible reason given as 'VISA:  (Hex 0xBFFF000E) The given session or object reference is invalid'. I am insure what the problem may be, and have checked all connection leads, and ensured that the interface card is still securely fixed in the PC!
Please Help!!
David D
(2,683 Views)
Hi!
Check that you have installed  VISA drivers on that PC.
else post the vi on forum.
Kaustubh
(2,661 Views)
Thanks for the advice!
Unfortunately it was a computer virus that had got into the system. It is ok now though,
thanks again,
David D
(2,656 Views)
