Problems about labview toolkit for Ti's DSP
Hello. Now I am using Labview tool kit to transfer data between labview and 6713DSK board.Now I have problems in RTDX. Becasue it looks like RTDX slow down my program. I use Timer 0 to trigger a ISR every 0.05 ms (20kHz), so it's a Hardware Interrupt(HWI). This ISR will call a STATCOM control function periodically (20kHz). Also will call RTDX in a very low frequency 33.3 Hz. The RTDX is supposed not to interrupt this ISR because it's a software interrupt and it's priority is lower than the HWI, right? But it do affect my ISR.Because the control function's frequency is slow down to 17.7kHz!! I disable all the RTDX functions and test the program again. Then I got the correct result: the frequency of the control function is exactly 20kHz. I check the timer 0 output and it's very accurate: 20kHz. So it should be RTDX influence my program. But it's very strange because the HWI should have highest priority, How can RTDX infect it? In the attachment I include my cdb file and the main function. Can you help me to find out why RTDX affect my program? And what kind of interrupt the RTDX is. Thank you.
(3,387 Views)
Hello, I am not that familiar with 6713 processor. I would definitely check TI with those questions as the questions are more related to the hardware than the LABView toolkit you are using.
(3,374 Views)
Yes. It's because DSP's BIOS memory setup/. After I move the BIOS code inside IRAM instead of SDRAM. The System runs great.
(3,366 Views)
specETO,
Hello. Now I used Labview toolkit to transfer data between labview and 6711DSK board. Can you tell me how to set up the
frequency of RTDX in DSP and Labview? i tried the TI DSP Test toolkit examples. i just received the data transmitted from DSP
C6711 DSK in about 1 Hz. How to set the frequency of RTDX in Labview and DSP?Thank you very much and I am looking forward to
hearing from you.
regards,
Danial
2005/10/20
(3,335 Views)
