Problems assigning channels on an AMUX-64t via a PCI-6025e DAQ
I'm new to this so it's probably finger trouble, I am attempting to read 2 channels (at the moment) on the AMUX-64t, but the virtual channels in MAX don't match up with the real ones on the AMUX i.e.
Ch0(MAX) = Ch3(AMUX)
Ch1(MAX) = Ch7(AMUX) and so on.
I'm using Labview 7.0 with an R1005050 cable.
(2,551 Views)
Simon,
Actually, each onboard channel corresponds to four AMUX channels. This means that if you read from channel 0 on your DAQ board you will be acquiring from channels 0 through 3 on the AMUX-64T. If you acquire from channel 1 on your DAQ board than this corresponds to channels 4 through 7 on the AMUX-64T. This is also described in the following Knowledge Base article.
How do I Address an AMUX-64T with an MIO Board?
http://digital.ni.com/public.nsf/websearch/c6d362737414ad6d862562a80070e694
The AMUX-64T User Manual will also prove to be helpful.
Justin Britten
(2,551 Views)
