Problems building exe that includes dsc (vi's always in memory, causing an error)
Thank you for your time and expertise. I am trying to build an executable (Win2000, Labview 6.0.2 and DSC) but am consistantly being told that a group of vi and ctl files are already in memory. I have removed all non-essential cards, restarted my computer and attempted to build from a blank vi. Nothing should be in memory. Would there be a service running (from boot up) that is causing this? There is nothing left in my icon tray that would indicate that this is so.
Please note that one of the vi's is entitled "dsc_Engine Status.vi."
Nathan
(4,255 Views)
Here is the problem:
You are attempting to build an application that uses VIs that are in memory. They are in memory for two reasons: One, you are using VIs that are used by LabVIEW, and two, they are used by LabVIEW DSC when it runs, by the service manager.
There are two solutions. One will get you there quickly. The other, will solve all of your applications building problems now and forever.
I will give you both and let you decide, however, I recommend the first, as it will solve your problems anytime you build an application.
Solution 1:
Open your top level VI(s). Open the VI Hierarcy. Select the option that allows you to view the path of the VI when you do a mouseover. Go to each and every VI, global, and control. Ensure that each is in your development or deployment directory, and NOT in /National Instruments/LabVIEW...etc directories. These are NI Core functions, and you should build with a copy only. This will take a lot of time, and may cause crashes (I had problems changing things in the hierarchy.) Try doing a "save all" about every 3 or so VI that you change. To change the location, you must first stop all services. Goto the Service Manager and select "Stop all Services". This should unload all the callers for these functions. Now, go to the hierarchy, and for everything in the LabVIEW directories, open it, and "save as" in your directory. This will cause the callers to look in your directory for the copy you are using. As I said, save all once in a while. Also, when prompted to affect the change in all VIs in memory, select YES.
When you have copied all resources, save all once again, and close everything, including LabVIEW. Now close LabVIEW. Take the directory into which you moved all of these functions, and move it off the computer temporarily (don't rename, remove to a different drive, or a zip drive). Then restart LabVIEW. If anything got moved incorrectly, you will be asked to search for it. Open a new VI, and select save all, to remake the file search paths stay with LabVIEW. Do NOT have your project open when you do this.
Now, replace your folder where it was originally, and restart LabVIEW. You can now build your application.
Solution 2:
Start LabVIEW. Goto the Service Manager and select "Quit Service Manager". When prompted, select yes to stop all services and quit.
Now build your application.
The reason the first solution is better is because you always want a copy of all NI Resource VIs, Globals, and Controls in separate location for your build. This not only prevents issues such as the one you mention above, but also solves a lot of other issues, including any changes to those core functions that may occur in newer versions of LabVIEW that may affect your program.
Good luck.
(4,255 Views)
A couple more tips:
--If you copy a VI into the clipboard, then it will reside in memory and prevent you from being able to build an APP that uses that VI.
--Make sure the DSC Engine is not loaded into memory (if you see an LV systray icon, then it is in memory).
http://www.medicollector.com
(4,255 Views)
