Problems compiling Database functions into installer
I am trying to build an installer for a test program I had written.  I am having issues with the Database functions, nothing is being written to the database, but stuff is being read back.  After I few tries I got fet up and included everything on the extra installers list, but it still does not correctly add the Connectivity functions (it was funny having a 1.6 GB installer though ).   The VI works fine before building it into an installer.
What can I do to add SQL write functions into the installer?
Andrew Lynch
Written with LV 8.2
(2,752 Views)
 Hello Andrew,
The following KnowledgeBase article should point you in the right direction if this application is written in LabVIEW 8.2:
KnowledgeBase: Building an Executable with LabVIEW 8.x and Database Connectivity Toolset
Cheers!
(2,731 Views)
