Problems editing in Labview 5
I'm undertaking research at my college and I'm having trouble editing a schematic previously created in Labview 5. I can load the program, and run it just fine. The problems occur when I try and edit it. I can add new functions to the schematic, and I can edit text values in the schematic (such as text in while loops, labels, and aqusition channel indicies in arrays) but I can't select the present functions or even new functions that I place, and I can't draw any connecting wires. The pointer only switches between a pointed finger and the text cursor. It's very strange. I've spent a few days searching through help files and searching the net, but I've not been able to find anything. I've never come across this problem in any of the Labview training I've had. Any help would be greatly appreciated.
(2,575 Views)
Can you post the VI or a part of it so I can try to edit it?  If you can, I'd like to see the behavior.  Please also post the version you're using to open it and attempt to edit it.
Thank you,
JLS
Best,
JLS
Sixclear
(2,555 Views)
