Problems exporting a LVOOP class to a .NET interop assembly
Talked with NI and it turns out that this issue (CAR 447058) is fixed in the 2013 SP1 f1 patch.  I've installed the f1 patch and my assembly works fine now.
Message 11 of 13
(1,171 Views)
We have the same problem with LabVIEW 2014 (no service pack). Is it possible LV 2013 SP1 f1 was released *after* LV 2014? It doesn't seem so.
The description of CAR 447058 says "Under certain conditions, LabVIEW cannot create a functional .NET interop assembly if the assembly contains LabVIEW Class." Whatever those conditions are, we cannot reproduce the error on a toy example and cannot get rid of it in our production code.
Unfortunately, we cannot easily try it with a later LabVIEW version (due to IT issues in a big company).
Any help is appreciated,
Peter
Message 12 of 13
(1,059 Views)
Hello Peter,
In order to get the best support on your question, I would encourage you to create a new Forum post. You are more than welcome to reference this forum, but a new thread will increase your visibility. I hope this assists in learning a solution sooner.
Ryan B.
Technical Support Engineer
Message 13 of 13
(1,034 Views)
