Problems graphing FFT of sine wave with Waveform Graph
I know that this type of question has been posted many times, so I apologize for posting a similar one. Unfortunately, after reading quite a few threads I still have a question or two.
Basically, I need to use a Waveform Graph (not an XY graph) to graph the magnitude of an FFT of a sine wave. I can't figure out which VI I should be using to obtain the magnitude of the FFT. I think I'm using the proper FFT vi (just the regular FFT.vi), but I can't find a VI dedicated to magnitude. Of course, I could be misinterpreting the pseudocode which I am following.
If you wouldn't mind taking a gander at my VI, I'd appreciate any input you might have. The pseudocode is contained in the block diagram.
You can see that I have another graph for just the sine wave, and I think that works as it should. I'm primarily concered about the waveform graph which isn't currently connected to anything, but should eventually be hooked up to the FFT.
Thanks!
(2,822 Views)
Your problem is that the output of the FFT is an array of complex numbers. Take the magnitude and you will be able to plot it.
(2,815 Views)
