Problems in Resistivity Measurement Setup?
We have a Resistivity measurement Labview(4.0).And we measure the Resistivity of our sample using this Program.The working principle for the measurement is the Vander Paw Effect. The problem is with the Determination of the Shear Factor(F) and the another value Q ( which is just a ratio of Voltages).
I have discovered that the program(it is a standard Purchased Software) instead of using the Q calculated in the program uses some predetermined array Q and the nearest value to the actual calculated Q is picked up from this array.The index is remembered and from the corresponding index in the F array( the SHEAR FACTOR) it picks the shear factor.This also takes a lot of time even though all the calculation are being done at roo
m temperature.Could anyone explain the Logic please.
Thanks in advance
Utpal
you can reach us at ::
(205)-348-7686
between 11AM and 3PM Central Time Zone
(2,931 Views)
Please post a copy of your code (all of it) or a image that we can look at.
It sounds like you like the results you get, but they are just to slow.
Is this correct?
Ben
(2,931 Views)
