Problems in calling c++ dll with strings after upgrading to LabVIEW 64 bit
We recently upgraded to LV2025 and since now all packages and drives we need are also available in 64 bit we decided to test a switch to 64 bit aswell;
On the surface level this all works fine and we actually were able to build our application and run it and like 99% of it is still working;
In our code we call a c++ dll to do some hardware interfacing; this dll was originally also 32bit but we just rebuild it for 64 bit;
To do that i upgraded the includes and libraries in the visual studio solution to the ones from: C:\Program Files\National Instruments\LabVIEW 2025\cintools
With that the dll was builable in 64bit without other code changes and can actually also be called in 64 bit mostly;
However with this function here:
We get LabView (in exe and development environment) to crash without any report or anything; Just a access violation can be found in the Windows event viewer; In 32 bit this doesn't happen.
From the c++ side the function definition looks like this: unsigned char __stdcall LVBusGetRxSignalList(LVStringIntArrayHdl out_signals)
with:
// A cluster with a string, and two int
typedef struct {
LStrHandle lvString;
int32 lvID;
int32 lviface;
} LVStringInt;
//typedef StringInt;
// A arraycluster with a LVStringInt
typedef struct
int32_t dimSize;
LVStringInt signals[1];
} LVStringIntArray;
typedef LVStringIntArray **LVStringIntArrayHdl;
Basically we expect both structures to still be correct especially since LStrHandle didnt change;
We then write the string from within c++ like this:
LVStringInt signal_info;
int32 len = stringToWrite.length();
LStrHandle handle = (LStrHandle)DSNewHandle(len * sizeof(uChar) + sizeof(int32));
memcpy(LStrBuf(*handle), stringToWrite.c_str(), len);
LStrLen(*handle) = len;
signal_info.lvString = handle;
This all works and actually also doesnt cause the error we see; The error only happens when Labview tries to read the string (name) from the struct again; So the code crashes in the for loop (see LV code above) when we unbundle the structure and access the name; If we onyl access the two integers it works fine;
Based on this it did more tests and simplyfied the call to just use a single LStrHandle and what i found is strange; If u use DSCheckHandle on the handle we get from LabView it returns 3 (mZoneErr) and trying to read the length with DSGetHandleSize will actually also cause a crash; And also no matter what you do in your c++ code and how acuratly you adjust the handle (edit; adjust size; dispose and create new) the code will always crash either in the dll or when accessing teh string in LabView;
For me this looks like a bug in LabView 2025Q3 64 bit as with 32 bit it works and i see no reason why this could or any of my test should crash in 64 bit;
Are there any ideas how to fix this; Am i doing something wrong or is this just a bug?
(246 Views)
Accepted by topic author defanbet
No, I'm using 32-bit and 64-bit compiling for LabVIEW DLLs frequently and have not seen anything that I would consider a bug there.
Do you have anywhere in your headers a definition like #pragma pack(1) or use in your project settings maybe Struct Member Alignment set to 1 byte?
That worked for LabVIEW 32-bit libraries but LabVIEW 64-bit has switched to default alignment.
Basically your LabVIEW struct declarations should be all wrapped into:
#include "lv_prolog,h"
// your LabVIEW structure declarations here
#include "lv_epilog.h"
lv_prolog switches to the LabVIEW required alignment (basically 1 byte for Windows 32-bit and default for pretty much anything else) and lv_epilog resets it to what it was before.
Your project can then use whatever settings the rest of your interfaces would need, most likely default alignment (8-byte) but the LabVIEW structs are then correctly defined no matter what.
Rolf Kalbermatter  My Blog
(233 Views)
Thank you very much!
that was exactly the issue;
Im not a c++ developer so this makes not much sense to me but we had
#pragma pack(1)
// our struct defs
// missing #include "lv_epilog.h" line
and now i just removed the pack(1) as we dont need it and added the lv_epilog line and it works fine;
Your fast answer is very appreciated!
(205 Views)
