I am trying to install Labview 7.1 on a network file server. The installation seems to be fine but when I try and run the application from a client computer the program fails to run. It shows up in the proccess list of Task Manager but then immediately dissappear. I had this problem with Labview 7.0 as well and it required a license key and an additional application that needed to be installed on the client computers in order for the program to run off of the network properly. Is that the case with Labview 7.1 as well?
