Problems making a stand-alon​e applicatio​n using a spectrometer USB2000+?
Hello all,
I have some problems building an installer in labview 8.5 for a stand-alone application that control a spectrometer USB2000+. I already included in the "additional installers" : LabVIEW run-time engine 8.5, MAX, NI VISA 5.1.1. Is there any additional installer missing?
 The MAX dosn't recognize the USB2000+ so the problem could also be with the drivers. Should I copy the labview drivers in some folder of the target computer?
The executable open correctly on the target computer but it puts an "VISA error" when i run it, so it confirms that there is a problem when communicating with the machine but I don't know what it is.
Thank you for any idea.
Amaury
(3,052 Views)
The USB2000+ would have its own drivers for the operating system. Even if they are using an FTDI-like solution to make the device appear like a serial instrument, that needs drivers. Did you install those?
(3,043 Views)
Yes I already installed the drivers for the operating system. Actually the USB2000+ works fine when I use the SpectaSuite software provided by OceansOptics.
(3,037 Views)
I already installed this Plug and Play instrument driver on the programming computer and my VI works fine with the USB2000+. The problem is with the "installer" that I installed on the target computer which has not Labview. Should I install this driver on the target computer? Because I already tried this but didn't find any directory "\instr.lib". Maybe the problem is more about the adittional installers I include in the installer; because I only included the 3 I mentionned above but I'm not really sure.
(3,018 Views)
What is the exact error code that you get? Did you export the hardware settings so they are imported on the new pc?
(3,014 Views)
The exact error code is -1073807346. Yes I exported the hardware configuration and it still doesn't work.
(2,989 Views)
