Problems opening mysql database connection
I am using the database connectivity tool kit to access a mysql database. The problem we've been having is the very first time a query is run after a period of inactivity it is extremely slow to respond (several minutes). After that the same query and other queries of the same database/table are fast 3-4 seconds.
We've been using the ODBC 5.1 driver but i wanted to switch to OLE DB to see if that would fix the problem. But I havent been able to get it to connect at all. I've searched the https://www.connectionstrings.com/ site and came up with the following:
Provider=sqloledb;Data Source=IPaddress, 3306;Initial Catalog=catname;
User Id=user;Password=bla;
but i get the error
Possible reason(s):
ADO Error: 0x80004005
Exception occured in Microsoft OLE DB Provider for SQL Server: [DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied. in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->db query test.vi
Looking in data sources it says SQL server version 6.01.7601.17514
Seems like an old version...maybe the connection string format is different but i havent been able to find it...
Anyone know the correct connection string and/or another possible cause of the delay in returning query results?? Thank you.
(5,961 Views)
Are you talking to mySQL or SQL Server -- that two different products. There are OLE DB drivers for mySQL but you aren't refering to them in the connect string.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,954 Views)
Thanks Mike, I think it's mysql. The original connection string was Driver=[mysql odbc 5.1 Driver} . I installed the mysql driver you linked to and tried
Provider=MySQLProv;Data Source=mydb;User Id=myUsername;Password=myPassword;
but i get
 NI_Database_API.lvlib:DB Tools Open Connec (String).vi->db query test.vi<ERR>ADO Error: 0x80004005
Exception occured in Provider: Unspecified error in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->db query test.vi
(5,947 Views)
is http://cherrycitysoftware.com/ccs/Download/Download.aspx equivalent to the my ole db you linked?
(5,943 Views)
(5,920 Views)
In theory they are, but I have never used the others. The ones from sourceforge I have and they work well.
Mike...
LabVIEW Champion
(5,932 Views)
You can do the following:
Create a text document on your desktop and rename it to something like connection.udl
Double click the file
Configure the settings and test the connection
Open up the UDL file in a text editor and it will contain the connection string.
aputman
(5,923 Views)
