Problems reading the serial port with labview 5.1.
I open the example serial.vi , I select write to serial port, run the programm, I don`t have any problem. But when I select read serial port, I get the error code 16392and hex code error x4008. I need to know what can I do? Thanks a lot
(2,659 Views)
Did you query how many bytes are available to be read at the serial port? Then feed this value to the READ Serial port?
(2,659 Views)
Any time you get an error in LV you can right click on the error cluster indicator and do a "Explain Error".
If you do this for the error code you reported, the explanation says that it was a framing error.
In serial communications, a framing error indicates that the hardware was not able to detect a start bit, data then the stop bits that comprise a frame.
This prompts me to suggest that you check you port setting on the serial port. You want to make sure you are setting the port for the correct;
Number of start/stop bits,
Baud rate
data bits
parity (just for good measure)
and hardware handshaking.
I hope this helps,
Ben
(2,659 Views)
