Problems saving a stack of images(Tiff) from a GigE camera
Hi everyone,
I am having trouble trying to figure out how to save a stack of images from my camera. I either get errors or end up getting prompted to save each image as it is taken. Ideally I would like to be able to select where to save the file once either via a prompt or drop down in the VI and that have the program save the rest of the files after that in sequence. (without a prompt) image acquisition.jpg
(4,315 Views)
An IMAQdx camera can take a single image ("Snap"), which you can save as a PNG or JPEG, or a video ("Grab"), which you can save as a Video file (such as .AVI).  The advantage of saving a (single) Video session as a (single) Video file is the basic simplicity of it all -- you open a single file, then feed the successive images (from the Grabs) to a IMAQ Write function that writes a frame of the video.
If you really want a sequence of multiple single images (such as a "stack" of PNG files), you need to generate a sequence of file names, as each image gets its own file (name).  Note that you can easily open a Video file, read a frame, write an image, and repeat until you've made PNG copies of all of your frames.
So for Videos, either a single Video file or multiple PNGs.
Bob Schor
(4,292 Views)
You are trying to use the same filename for each picture. You can generate unique file names using something like the loop iteration or a time-stamp.
(4,252 Views)
Thank you for your kind replies!  I'm trying to implement some of the things you two have  mentioned.
(4,236 Views)
