Problems to find created VI s
when I want to use the enveloppe.vi as teststand step which is discussed under:
http://forums.ni.com/ni/board/message?board.id=170&message.id=153740&requireLogin=False
 Then teststand asks for the follwing vi s
"Fast Hilbert Transform.vi"
"1D Rectangular To Polar.vi"
"Read From Spreadsheet File.vi"
But I only can find the following vi s:
"hilbert.vi"
"Read Write Spreadsheet File.vi"
"File Read Spreadsheet.vi"
"File Read Spreadsheet to Table.vi"
when I want ot use "hilbert.vi" instead of "Fast Hilbert Transform.vi"  it asks me to select "Fast Hilbert Transform.vi" again.
how can I solve this problem?
regards samuel
(2,809 Views)
Hi Samuel,
Which version of LabView do you have?
The "Fast Hilbert Transform" VI is not included in LabView Base Edition; you need at least the Full Development System.
Johannes
(2,782 Views)
Johannes,
where can find if it is the bease version oder full development verison
regards samuel
(2,768 Views)
Hi Samuel,
you can find out which version you have installed in
Start Menu -> National Instrument -> License Manager
In the LabView category, there is a green square next to the version you are using (Base, Full, Professional etc.).
Johannes
(2,762 Views)
