Problems using PCOMM32.DLL Delta Tau PMAC Driver Library
Are you doing dll calls, or using ActiveX with Pcomm server?
Message 11 of 12
(2,325 Views)
Hello
Thanks for your quick reply. I am using a dll call at the moment. The command i'm trying to call is: PmacDownLoadA() which according to the Pcomm32pro manual should have structure:
long PmacDownloadA (DWORD dwdevice, DOWNLOADMSGPROC msgp, DOWNLOADGETPROC getp, DOWNLOADPROGRESS pprg, PCHAR filename, BOOL macro, BOOL map, BOOL log, BOOL dnld).
I have attached the VI I have tried to use. However this crashes my Labview! I think it may have something to do with how I deal with the 2nd, 3rd and 4th inputs (I was not sure what these should represent). Also I have had to use a string for the file path and not a proper labview filepath input which I think may also not be helping.
Any help you could provide would be great!
 Martyn
Message 12 of 12
(2,312 Views)
