Problems using "call library function" vi!!
Hello!
I am using "Call library function" and I have a problem.
IWe have a dll (I haven´t compiled this dll, but I know that the source code is .NET), the dll has a function that is used to initialitates a driver, it has no input paremeter, and a return value (boolean).
When I configure the "Call library function" , I browse the dll, but it doesn´t appear the name of the functions that contains this dll. Could it be a problem in a dll?Do you have to compile the dll, doing "something special"?
Is posible to use this vi with a dll which its source code is .NET? What calling conventions can we use? I have read something about calling conventions in "Using external code manual" but it doesn´t clarify me.Could you explain me more about calling conventions?
Thaks in advanced!!
Graci
(2,811 Views)
Sounds like in the compilation of the DLL the function wasn't set as an dllexport function.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(2,801 Views)
The question is how the DLL was designed to be called. Typically if the DLL is a .NET DLL (aka .NET assembly), then you can't call it with C-style calls (such as the Call Library node). Instead, you need to use the .NET palette, which was introduced in LV 7.
It is possible to have a .NET assembly expose C functions that can be called by the Call Library node, but it's very rare. I'm assuming that you most likely need to use the .NET nodes in LabVIEW.
(2,795 Views)
@Gracinda wrote:
Hello!
Thaks in advanced!!
Graci
A .Net DLL does normally not export C functions but a .Net interface instead. You can't use the Call Library Node to call a .Net interface but need to use the specific .Net functionality in LabVIEW.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,786 Views)
