Problems when using C# dll or C dll
what does this mean ? I do not quite understand,thank you~~~
Message 11 of 31
(1,623 Views)
And for the reason... The dll is a licensing dll. The code validates the file's hash against a hardcoded hash, to make (reasonably) sure it's not modified.
yes ,you got my idea. but ,what does your "reasonably" mean ?  are you saying "there is no use " ? do you have better method to ensure it ?
any suggestion will be appreciated, thank you ~
Message 12 of 31
(1,622 Views)
wiebe@CARYA  已写:
@rolfk wrote:
Sounds like a maintenace hassle to me! Signing of the DLLs would seem more secure and part of the build process. For signed DLLs the OS will only load them if the signature is valid.
Didn't say it was a good reason Smiley Very Happy.
The maintenance is OK for now, the dll only changes once or twice over the few years. Maybe easier then managing certificates, the application is distributed to a lot of systems (>50?).
I can not quite get your attitude or opinion Smiley Embarassed, Do you agree my usage or agree the signing usage ?
Message 13 of 31
(1,620 Views)
@rolfk  已写:
How to sign the DLL ? when building exe or installer?  Forgive me , I am not an experienced programmer, I am just good at engineering and want take my idea into practice. thank you
Message 14 of 31
(1,617 Views)
@rolfk  已写:
If you still think that this is a superintelligent thing to do, you should look at the open mode of the File Open node. It's default value is NOT compatible with accessing a file that is already open by someone else.
I suspect that the key should be in the DLL, decide allowing others it or not when being used , not the new user to decide by consciousness.
Message 15 of 31
(1,614 Views)
@rolfk  已写:
If you build an exe and start it it loads everything including the DLLS and then stops executing and unloading everything each time. Process creation and tear down in Windows is even more costly than loading DLLs so the additional overhead is not such a concern. In the LabVIEW IDE your program is just a script executed inside the LabVIEW IDE and the process remains fully alive all the time until you shutdown LabVIEW itself.
it seems it is because the optimization when build the exe that disappeared the errors , not the exe start or stop RUN, do you agree ?
Message 16 of 31
(1,612 Views)
@rolfk  已写:
ans: I have no other solution but this, because the OEM supplier is for Internet usage ,just offering JAVA\PHP\C#\C source code as API, considering the security, the only way I can do is to bulid a DLL and call it .
Message 17 of 31
(1,611 Views)
ans: I have other solution but this, because the OEM supplier is for Internet usage ,just offering JAVA\PHP\C#\C source code as API, considering the security, the only way I can do is to bulid a DLL and call it .
 As already mentionded, look at the default values of the File Open node! It is by default opening a file for read AND write access. That is not compatible with a file that is already open elsewhere. The error code that is returned by File Open could have told you that.
What is reasonable is in the eye of the beholder. But a simple hashing algorithme with a comparison to a fixed value will only dwart the casual hobby hacker. It will not keep out the determined hacker. Figuring out the hashing algorithme is not that difficult. It's actually a little more involved in LabVIEW since most people have no idea where the actual executable code is located in a LabVIEW program, but it is compiled code too, just as a normal DLL and can be therefore looked at with a debugger. From that its fairly easy to deduce the nature of simple algorithmes and slightly more complicated for more complex algorithmes.
Rolf Kalbermatter  My Blog
Message 18 of 31
(1,594 Views)
@alii001 wrote:
wiebe@CARYA  已写:
I read a .NET dll as file myself, for the same purpose of validation.
Signing might be a more elegant solution, although potentially also a hassle.
I'll stick with .NET file hash validation for now. It works for me, because the .NET dll is very stable. If the .NET dll would change often (e.g. recompile), the certificate signing might be worth exploring.
Validation of the file is the only 'good' reason I can think to read the .NET dll as a file. I quoted good, as it is a bit crude.
Message 19 of 31
(1,588 Views)
@alii001 wrote:
@rolfk  已写:
Although LabVIEW executables can be signed, this is about signing the .NET assembly. If the .NET assembly is signed, changing it will invalidate the signature, and Windows won't run it anymore.
So with a signed .NET assembly, you wouldn't have to change the LabVIEW hash that is embedded somewhere every time the .NET assembly is recompiled. That would be beneficial if the .NET assembly changes a lot, or if it is updated in a different cycle as the LabVIEW application.
I'd say the LabVIEW application would still need to check if the loaded .NET assembly is properly signed. If it doesn't the entire signed assembly can be replaced with an unsigned assembly, and Windows wouldn't mind as it's not signed at all.
I have no idea how to sign a .NET assembly. That's a question for a .NET forum, although I'd answer if I knew. But I don't.
Message 20 of 31
(1,585 Views)
