Problems with ActiveX and an IRtrans-modul
I have a problem with an IRtrans-USB-modul. This is a modul for learning or sending infrared commands.
The modul is connecting to the USB-port and supports ActiveX and .NET protocols.
I have registered the ocx-library with the command regsvr32 and in LabVIEW I have the selection for the ActiveX-class.
But when I use a method and will send or learn a command I get the failure: Exception occured in Winsock, wrong protocol or connection status for the prompted transaction or demand. Help path in MSWNSK98.chm and context 1040006 in Unbenannt1.
With the supplied software from the manufactor the modul is working fine.
Somebody is using this as well? Or somebody could help me with this problem?
(2,904 Views)
Hello Tweety,
I've installed the software for the IRtrans module. Unfortunately, I can't start a server, because for this I have to connect this module.
If You can select the methods of the IRtrans objects in LabVIEW, the activex connection should be OK. Make sure, that You use the right parameters and the right data types.
Here is a link to the software, I've installed. Do You have the same Version?
http://www.irtrans.de/de/download/windows.php
Klaus
(2,882 Views)
