Problems with Application builder after applying LV2011 SP1
I installed the SP1 upgrade for my LabView 2011 from the dvd that NI sent out.
I have a license for LabView 2011 Base and Application Builder.
Everything worked perfect before the upgrade.
The build of applications and installers goes fine with no errors. The build was done on Win7 32bit.
When I try to install my application I get error. I install them on Windows XP 32bit.
"The NI Uninstaller installation has failed with the following error:"
"The NI VC2008MSMx x86 installation has failes with the followin error:"
"The NI LabWindows/CVI 2010 SP1 Low-Level Driver (Original) installation has failed with the following error:"
The are more errors when I press continue but I chose not to list all of them now.
I get no errorcodes, it's just blank. Se attached pictures.
(5,153 Views)
I just ran into this same issue today.  The installer was built just fine, then I copied it to a virtual machine to test it out in a clean environment.  Then I get the dialogs as you shown with no explaination, one for each product it tries to install.  Any information about what could cause this or where to get a more verbose explaination of the error?
EDIT:  By the way I am having this use on LabVIEW 2012 SP1 Built installers.
(2,617 Views)
