Problems with DAQmx Assistant
Hi @ all,
when I want to start the DAQmx Assistant in Lab View 8.6, I get following error message "NI Assistant Host has encountered a problem and needs to close". Can someone help me?
User10
(3,102 Views)
do you have Visual Studio 6 installed on the same system?
Tobias
(3,073 Views)
if yes, try to update the pdm.dll as suggested by Microsoft
http://support.microsoft.com/kb/293623/de
(3,072 Views)
Thank you for your answer, I tried this but the error happened again. Do someone knows a solution of this problem?
user10
(3,049 Views)
