Problems with Datalogging using a SubVI
Hello!
I have a big Program, that uses a SubVI to collect/send Data via a ISM111. But i doesnt work - i doesnt comunicate with the ISM!
I tried a single prog, that only uses this sub, then it works.
Where could be the error? Is it perhaps te use of Local var?
Need Ur Help!
Thx
Zwitsch
(3,069 Views)
I think there are just some coding problems in your application. Maybe some-one can review your code or just your subvi.
I also use a single subvi to read/write data to an external device in applications.
Generally it should be no problem, but it can be that detail you overlooked.
(3,069 Views)
I agree with PdB. You need to be especially careful when using those local and global variables in any program. You may want to check that you are actually writing to these variables before you read from them. However, it is always best to avoid using these unless absolutely necessary.
Mike
NI
(3,069 Views)
Okay, so i should avoid using Locals...
Okay, thanks, if i have further probs i post 'em. Tomorrow i can try that.
Thanks 4 ur postings!
Zwitsch
(3,069 Views)
